smart tv
(Topic created on: 31-10-2020 05:57 PM)
sara10120
Hi I can log on to Samsung account on my mobile but I cant log into it on my smart tv.Just trying to download a app on to the tv.
8 REPLIES 8
DUMITRU79
Troubleshooter
Hi Sara. What is the message that appears on the TV when you try to login to your Samsung account ? What's the TV model ?
AndrewL
@sara10120: Just to check, are you attempting to sign in via Settings > General > System Manager > Samsung Account > Sign In? If so, please confirm the details from the post by @DUMITRU79 and I will look into this further for you.
sara10120
yes I am
sara10120
model number is UE50TU7020KXTU
sara10120
All it says is I'd or password is incorrect but my login works through my mobile.
DUMITRU79
Troubleshooter
have you tried a factory reset on your TV ?
sara10120
No its brand new
DUMITRU79
Troubleshooter
It might be the case , but , if for some reason, the settings are preventing you to log in , resetting the TV might do the trick
