Smart TV is stuck in continuous Software Update
(Topic created on: 02-01-2021 01:39 AM)
SingaporeSaint
This kicked in on 1st January so I assume there is a bug in the software but my TV is stuck in software update mode.. shows the software update message, restarts, shows the software update message, restarts, etc.  I can’t access the menu or do anything to interrupt it.
I let it run for 30mins or so before switching off, but same thing happens when I turn it back on.
Anyone else had the same thing happen and been able to sort it?
4 REPLIES 4
Pugs1957
SuperStar
Try disconnecting from the mains for a few minutes and try again.
un55d7ooo
Samsung Liason, TV model # UN55D7000 s/n   z30Q3CAC1oo739A
problem -  does not stay  Logged in to netflix after i power down for the night.
Next day I turn on smart tv, then smart hub,  then choose netflix ( first app in list )
.  I see a red NetFlix banner with a blank white box below it centered on my screen.
next step I have to  Exit,  then choose  netflix app a 2nd time,
I get a screen with a toll free 844 #,  then  click Member sign in.
On Member sign in,  I key in e-mail & pswd ,  but there is no "remember: me" option.
So  every time this has to be repeated, each consecutive day that I want to watch netflix.
Arzian
My TV is doing the same.  It is stuck on a software update loop.  Did you ever find a solution?
BinCrawler
I too have the same problem. I have a UN85JU7100F and it continuously display the update message, then reboot and pop up the same updating message then reboot ... repeat.
