29-11-2022 06:58 PM
Hi, I have a 2015 ue55ju7000 TV, the original remote that came with it is dead (was dropped and smashed) =
BN59-01220D
I have the option to get a remote for a 2014 "H" series TV = BN59-01185B but i need to have it posted to me.
I dont want to go through that trouble if it wont work for my model TV, I can not find any info on cross compatibility of remotes.
They seem to have the same options and controls but would like to make sure before i get the new remote posted to me.
Does anyone have info on smart remote cross compability?
Thanks
30-11-2022 12:22 AM - last edited 30-11-2022 12:28 AM
Hi @cm2022 There are a number of Remotes which would be compatible and Universal ones pretty certain to be fine,could not say for sure about BN59-01185B though . some information here https://www.samsung.com/Compatible Remotes It is though a Us link and Samsung Spare parts for the Uk is here,did not find precise model number there though. https://www.samsungspares.co.uk/sound-vision/tv
Did find this specific one which mentions your model on Amazon https://www.amazon.co.uk/Samsung-UE55JU7000-121AV-Batteries-Included/dp/B072HHFXZD
30-11-2022 09:24 AM
Thanks for the assistance James, I will have a look through the links and update my results for any future question askers!
