08-01-2019 12:54 AM
- Mute
- Highlight
Hi my samsung smart tv is suffering form this problem for a month now. Can some tell me how to fix this?
25-02-2019 01:25 AM
- Mute
- Highlight
Hi,
My Samsung Smart UHD tv showing internal Available Memory as ZERO MB. can you please share the instructions to recover storage? if that helped you.
25-02-2019 06:41 AM
- Mute
- Highlight
Hi Biven
I could fix this problem with EEPROM reset. It works with and above UN7400 as I heard.
Press the physical ON/OFF button on your TV. Should be somewhere at the middle of the edge, mine is at the bottom side, behind the Samsung logo. So press the button an hold for at least 3 seconds. Then press the ON/OFF on the remote within 10 seconds and hold for at least 3 seconds.
You should see your TV rebooting 2 times. If don't, then try again.
Please note, it's a factory reset, so I would advise to save your channel list, picture settings, and so on first...
03-05-2019 01:04 AM
- Mute
- Highlight
I don't have a physical on/off button. How do I do a EEPROM reset?
03-05-2019 10:02 AM
- Mute
- Highlight
I can't answer. Have you checked the user guide? Normally every TVs should have. Sometimes hidden. Mine is behind the SAMSUNG logo in the center...
07-07-2019 11:00 AM
- Mute
- Highlight
Hi mate,
I did the Reset test upon your steps, but still i am facing the same issue, i cant install any apps, even when i do the Smart HUB connection test, the last test which is THE APPS TEST, it said(UNABLE TO compelet Apps test )
your respons and advise is high appreciate,
Mustafa
IRAQ
05-08-2019 11:14 AM
- Mute
- Highlight
Excellent, having tried everything else to solve this problem with my SmartHub resetting the EProm as per your instructions resolved it. Thanks
24-11-2019 12:27 AM
- Mute
- Highlight
29-11-2019 12:04 PM
- Mute
- Highlight
This method really works for me!! Thank you so much
30-11-2019 03:17 PM
- Mute
- Highlight
01-12-2019 01:00 AM
- Mute
- Highlight
None of the suggested work arounds worked for me, but the following did:
Push the Smart Hub button on the remote.
Scroll to the Samsung Apps icon on the bottom of the screen and click the enter button on the remote.
you should see a Smart hub updating progress bar.
After that, the apps should work.
