Smart hub Display Time
(Topic created on: 08-04-2020 06:08 PM)
delibelli
Is there a way to adjust the amount of time the Smart Hub displays after you exit any other menu? It stays on for so long! I can clear it by pressing Exit again but surely it can be set to just display for a few seconds??
4 REPLIES 4
CarlH
Hi @delibelli. I'm not sure but I can certainly look into it. Which model do you have?
delibelli
Its a UE43RU7020KXXU
thanks!
paperboy2
Did we get an answer on this?
I would also like to reduce the amount of time that Google Assistant remains on screen.
Thanks in advance
Lharts
Hi,
is there an update here? Would really love to change the timeout setting…
