10-07-2024 09:54 PM
Hi. I have a The Frame (2022) GQ65LS03BAUXZG.
I also have a Neo QLED QN94A which has no Smart Connect Box (adapter). I was wondering if also Neo QLED modem are available with smart connect box? I just found QN95B. Can I use my The Frame (2022) connect box also for the QN95B? The thing is my smart connect cable is in the wall so I want to keep it but would like to replace the frame with a neo qled (4k is enoug).
Next Question. Why decided Samsung to have a Neo QLED from 2022 QN95B and all newer models changed back to classic connectors? Where there any issues with the smart connect cable in combination with neo qled or why is only on model of QN9… with a smart connect box?
12-07-2024 07:15 PM
