Recording issues
(Topic created on: 10-07-2024 06:11 PM)
Apples33
Hi all
i have a UE32D6530 which developed a fault with the MB, i swapped out the MB but my previous recordings wouldn’t play I got a drm message, I recorded something from the tv to check and it recorded no problem, I then formatted the usb stick to FAT32 using my laptop which it was originally but now when I plug the usb into my tv and try to record it tells me it needs formatting before it can be used, so I choose to format but then after the tv performs a test it fails and I get an error about timeshift and cannot record
can anyone tell me how to fix this as before the MB failed it worked fine
thanks
0 REPLIES 0
