Screws to fix wall bracket to back of T5300 32" HDTV
(Topic created on: 22-01-2023 03:51 PM)
Duffy3
TV
What size screws do I need to fit a wall bracket to the back if the TV. None came with the TV and I bought some M6 x 30mm but they don't seem to fit! The screw holes seem to be buried low down and difficult to get assess what size is required. Why don't the supply with the TV??
Thank you
4 REPLIES 4
TRY2HELP
Helping Hand
TV
normally you don't get bracket screws with any tv, but when you buy the wall brackets it alway comes with the screw that fit for all tv models
Duffy3
TV
Thank you
I had the bracket that was on a Toshiba TV that packed up. Bought the Samsung and the plate that fits on the back goes over the holes on the TV fit over them but the screws don't fit as they are not long enough so I bought some M6x30 screws that I had been advised to get. They don't fit. So I am going to try M4. But Samsung should say what size is needed, but they don't. Seems weird to me!
SereneH
TV
@Duffy3 Standard dimensions for wall mount kits can be found on page 12 of the user manual on our website: BN68-10528E-00_UM_UT5300L_UT4300Z_XU_ENG_200225.0.pdf (samsung.com)
Duffy3
TV
Thank you
