Size of M8 Screws for Wall Bracket
(Topic created on: 4 weeks ago)
DL72
Hi
I have purchased a new UE55CU7100K TV and the M8 screws that I purchased separately to mount the TV on the bracket are too short. Can you advise the length of M8 screws required. Thank you
2 REPLIES 2
Robin999
Black Belt
What length are the screws you have? How short are they? Are we talking millimeters? 21-23mm seems to be the correct ones.
Gurky
Helping Hand
Hi, it's M8 20-22
