Go to solution Solved
Screen Mirroring 46UEF6800 not working with S7 edge Android 7.0
(Topic created on: 16-04-2017 05:10 PM)
psssmarina1
Pathfinder
Hi All
I have a problem with screen mirroring.
My tv has last firmware 2126 and the screen mirroring work with Samsung Tab S2 with Android 6.0. It does not work with S7 edge Android 7.0
The screen mirroring of the S7 edge works with a Samsung Tv 40UH6900, so I don't know if the problem is of the phone or Tv.
Can you help me to solve it?
Thanks
        Marina
Go to solution
11 REPLIES 11
Oskar
Hi.
Not sure how it resolved and if it is completely ok now. It has been working a lot better recently. I suspect a software update or possibly another app's setting which might've had something to do with it.
Sorry I can't be more helpful.
Good luck!
amemoore
Yes! We are having the same very frustrating issue with our S8
Never had that problem with our last phone. S5 or 6
Everything states top turn off WiFi direct... but it's WiFi Direct or nothing... so that doesn't work.
We purchased Sling and now can't use it on our TV
It's not an app we can find on our Samsung Smart t.v. either
Tags (1)
