Go to solution Solved
Screen Mirroring 46UEF6800 not working with S7 edge Android 7.0
(Topic created on: 16-04-2017 05:10 PM)
psssmarina1
Pathfinder
Hi All
I have a problem with screen mirroring.
My tv has last firmware 2126 and the screen mirroring work with Samsung Tab S2 with Android 6.0. It does not work with S7 edge Android 7.0
The screen mirroring of the S7 edge works with a Samsung Tv 40UH6900, so I don't know if the problem is of the phone or Tv.
Can you help me to solve it?
Thanks
        Marina
JordanH
Pathfinder
Could you remove the connection between the TV and the phone/ Forget the connection?
What error are you receiving?
Could you go into your Gallery on your phone and select a photo. After this, could you tap share and then press on the Smart View button. Does this connect?
Have you tried installing the Smart View app from the Google Play store?
11 REPLIES 11
JordanH
Pathfinder
Hi @psssmarina1.
Could you send a little more info on how you're trying to use the Screen Mirroring?
Are you on the Wi-Fi or 3G when you're doing this?
Could you connect to your Wi-Fi then pull down on the top of the S7 Edge screen and select the Smart View icon.
Do you have sidesync installed on your phone?
If you do, could you try connect to the TV via sidesync. If this doesn't work, could you then un-install sidesync and try to mirror to your TV again? :smileyhappy:
psssmarina1
Pathfinder
Hi Jordan,
thanks for your anwser.
So, I'm on wifi, and I connect exaclty how you describe. I pull down and select the Smart View icon.
The TV and the phone see each other, the both say "connecting to ... ", but after few seconds there is an error.
How do not have sidesync on my phone. Should I try it?
I remind you that the connection between S7edge and Samsung HU6900 works.
      Marina
JordanH
Pathfinder
psssmarina1
Pathfinder
Hello,
I followed your suggestion of selecting the photo in the Gallery,  and then connecting using with smart view. And it worked. After that also the screen mirroring works.
I do not know what was the reason for not working,  but thanks very much for your help!
Marina
JordanH
Pathfinder
That's great to hear, @psssmarina1
Enjoy your Screen Mirroring. :smileyhappy:
Oskar
Hi. I have a similar issue with my samsung tv and galaxy s7 edge regarding screen mirrioring. I am unable to display any content from my phone to the TV. But for some reason I am able to watch TV content on my phone, as well as the function to hear TV audio on my phone. I've tried the gallery shortcut key (no luck - TV starts connecting and after 20 sec displays a black screen without any pictures). I've tried connecting from the quick settings shortcut key "Smart View" with absolutely no luck. Also I've tried from the quick connect settings and still no luck. In addition I've forgotten and reregistered my TV to no avail. Also I have tried connecting to the TV at work (no luck). My friend's S7 works fine with my TV and the TV at work so the issue has to be with my phone. The problem stared after upgrade to the newest software on my phone. (Android 7.0) or quite possibly even before that. It worked fine before. Also I tried deleting the samsung connect cahce from application manager with no luck. Restarted the phone loads of time. Seems like I've tried everything up to factory reseting my phone. Any ideas what could be the issue?
Oskar
Also Sidesync is not working properly on my phone.
JordanH
Pathfinder
Hi @Oskar
If the above steps that I suggested previously didn't work, could you give our Contact Centre a call on: 0330 726 7864
They're available to contatc Monday to Saturday between 9am-6pm.
Bush333
I have the same problem. What was this fix for this? Thanks
