SAMSUNG UE75TU7020KXXU 75" Smart 4K TV aerial cable not fitting
(Topic created on: 11-02-2021 11:01 AM)
Jeepz
I have a 'CDL Micro TV Aerial Cable (M-M) with Adapter (F-F)' bought from Amazon & it isn't fitting into the TV ANT IN (fits fine in my wall socket). The provided adaptor isn't making any difference neither. Can anyone suggest a cable that will suit this TV (the back panel has a protruding covering that seems to be limiting what width the antenna cable can be in order to fit as it does partially fit into the TV socket but it's very loose & isn't a good fit in the same way as it is to the wall socket)?
1 REPLY 1
Jeepz
Called Samsung support who informed me I require a Coaxial Aerial F Connector Male Plug to RF M-Male Cable
