Samsung UE50MU6120
(Topic created on: 09-01-2018 06:41 PM)
TazmanUK37
Hi just bought this TV.
Anyone have any good calibration settings.
Also online chat said the only difference between this and the 6100 is the one remote and Bluetooth, but was told it's capable of Bluetooth as it has the BT module still in just switched off.
So will Samsung enable this in a future update, and will future firmware better the picture.
As I have a virgin V6 box, on 2160p setting using a 2.0 HDMI I see on channel 5 right across the top there is juddering video, but goes in 1080p output, issue with V6 or issue with TV??? Issue is on a few SD channels on the V6 box, channel 122 has like a light bleed frames all around half an inch from frame.
But goes if put in 1080p on V6. Odd on!
10 REPLIES 10
valleyboy22
Voyager
Hi,
I also have a v6 box and can i just ask you have you managed to link your universal remote ok? Alkl good my end and i can turn the v6 on via remote, but still not managed to figure out how to put it on standby and have u?
I had it set up to uhd on my v6 and i also put it back to 1080p because i was not really happy with it. Not sure if its a v6 and samsung clash issue? The judder issue u see i still get this which i have tried in motion plus settings to reduce this, but the lower you put the settings the less HD quality it produces?
TazmanUK37
Hi I don't have the Samsung one remote
paul1111
Hotshot
Ask you retailer for one.
TazmanUK37
6120 does not come with the one remote only 6100 Bluetooth disabled in 6120 hence not included with the tv
valleyboy22
Voyager
Ah right sorry. Was just after some advice also regarding my V6
TazmanUK37
Oh right, the VM V6 box remote will only do volume up, volume down, mute and standby for your TV.
In the help section on V6 box there is remote codes and tells you key sequence on how to re write the code.
valleyboy22
Voyager
How do you get to put it on standby please? Can put it on etc but cant figure out to turn it off?
valleyboy22
Voyager
Meant V6 on standby sorry
TazmanUK37
Longer press on standby button V6 TiVo remote if the remote has been paired correctly, you'll know as if mute, volume up, down, will be working.
Just try a longer press
