Samsung UE43RU7025
(Topic created on: 23-02-2020 04:34 AM)
luisfreitas
Good night, folks,
I recently bought this TV, the picture is OK, but somehow I can't find the HDR and the UHD COLORS anywhere in the options. Is there any problem with the TV? Or those options only appear when I connect any device supporting HDR and UHD COLORS?
The only thins I have connected is a TV BOX in HDMI1.
Thanks in advance!
4 REPLIES 4
AndrewL
@luisfreitas: If an external UHD player is connected to the TV, use the HDMI UHD Color function to convert the TV's HDMI connector to a mode optimised for the UHD 50P/60P signals.
Settings > General > External Device Manager > HDMI UHD Color > Select the port that the device is connected to > On.
luisfreitas
@AndrewL but so far that option doesn't appear either...is it something wrong with the tv? Or do those options really just appear when I connect, for example, a ps4 pro?
AndrewL
@luisfreitas: I believe so - the connected device would need to be UHD ready in order for the option to be available in External Device Manager.
luisfreitas
@AndrewL I will try it with my PS4,  I believe the 1st model also has now the 4K ability and the HDR. I will get to you after I tested it. Thanks for your help! :smiling-face:
