Samsung TV power settings
(Topic created on: 20-12-2022 08:42 PM)
rugbykiwi
Hello is there a way to stop the notifications coming up every time I change picture mode?
It always comes up with "changing this setting may increase power consumption"
15 REPLIES 15
Dave_j17x
Yes it works, at least on a QLED 4K QN88C and I'm pretty sure the inputs work on any screen to enter the factory menu.
Dylanoil
Legend. Worked. Thanks!
Members_4a2teAP
I have the same problem with repeated "Changing this feature may increase power consumption" message on switch on. It only seems to have started recently and we haven't deliberately changed anything. Perhaps a setting has been changed accidentally.
I have tried the link posted by Dave_j17x, but despite being logged into my Samsung account, I get a message saying that I don't have sufficient access to view it. "You do not have sufficient privileges for this resource or its parent to perform this action.")
Can someone post the steps needed to return a Samsung TV (QE55Q60) to settings which don't prompt the warning message?
Dave_j17x
This thread has multiple pages, I already posted my notes on how to do it to someone else. Check the whole thread!
rugbykiwi
See above it worked for me... If not working for you then I'm not sure .
Members_Dt4KoZk
hi,
I used this method in the past, but my tv updated automatically (and energy popup back) and now i cant enter.
First part ok: Mute > 1 > 1 > 9 > OK > OK
but i entered "1 2 3 4" and nothing change now in the screen (fms not appear)
my tv is: QE55Q80AATXXH
firmware: T-NKM2DEUC-2220.9,BT -S
if somebody have the solution now, please tell me
thank you
