Samsung TV AU9070 Crystal Clear UHD Max Resolution
(Topic created on: 29-12-2022 11:17 PM)
Luca1097
Hello. I was wondering if I can get some help with a couple of doubts that I have since I've bought my tv, and unfortunately so far I did not get a straight and definitive answer to them.
I'm using my AU9070 as a monitor for PC  as well, with very good results at 4096 x 2160 @30Hz resolution, which is also the maximum my intel integrated graphic chip is capable of via HDMI.
I'm about to get a dedicated graphic card, and what I was wondering, is if my tv will support 4096 x 2160  @60Hz instead of only 30, and what is the max resolution supported, please.
Thank You.
0 REPLIES 0
