Samsung smart tv curve UA48.J6300AKXXA
(Topic created on: 23-12-2022 09:21 AM)
Mbujaja
Hi guys I have a problem with my Samsung curve smart tv.. it’s not responding to anything I can see the red flash on the bottom corner whe I press the remote or press manually at the back. The tv has a white and black noise on the screen.
3 REPLIES 3
TechnoLogical
Voyager
The hdmi may not function well. Check if the port is not bent and check the device your connecting it t o
Mbujaja
It’s not connected to anything at the moment it’s just the power plug,I can’t open anything even the menu or smart hub
Mbujaja
When I plug an antenna it fixes the picture of the Chanel that it’s currently on but it can turn up nor down the volume
