Samsung qled frame backlight bleeding
(Topic created on: 06-01-2021 02:46 AM)
QLEDframe
I am facing issue with backlight bleed on my new samsung frame tv. Which is a month old only I have contacted service centre's they replaced the qled panel but issue still persist, and engineer has to say that panel works in this way only, what a shame to such big display company that simple issue cannot be fixed. Again contacted samsung service head of India its been two weeks no action taken , seems samsung don't care about customer any more
28 REPLIES 28
Goutham
I am facing this issue as well, how long did they take to replace the panel, and were you allowed to keep the tv till the replacement had arrived??
Thanks
look4vikas
I also recently bought the same TV and see the same problem. Do you have a latest update from Samsung?
Ruu
I am facing the same problem with Samsung Frame 2021. I think the panel in this new TV isn't that great for Indian versions
Kushagra Gupta
I am facing the same issue with The Frame 2021 QLED TV 😞
QLEDframe
Hi all yes it ha been solved now...panel was changed by Samsung wothin a week had to write to service head of samsung...
Still after replacement it was same..samsung couldn't find a fix...
However what i did is I lifted the panel away from wall by adding some gap between wall with the help of 2 screws provided in box...and that fixed my issue...frame word is just marketing stunt..it doesn't work as frame it work like normal led tv do no throw ur money for this model better go for lg or sony
QLEDframe
QLEDframe
Agree with you
QLEDframe
Sory for responding late
WinguNotts
Hi i have my tv on stand and have same issue like yours , can you show how you manage that ?1.jpg2.jpg3.jpg
