Samsung Q series - Limit Volume
(Topic created on: 13-09-2019 01:19 PM)
Robertjan88
We recently bought a Samsung Q series and want to make sure that, when we are out, our younger family members won't crank up the volume to disturbing levels.
I noticed that several brands do allow people to limit the max volume. Is this also possible for our Samsung Q series?
When so, what steps should we take?
Thanks!
2 REPLIES 2
JAMES4578
Samsung Members Star ★★
Thanks!
Hi @Robertjan88  Not sure if you are using Sound Bar or Tv  Speakers but in any case you may  to switch to Tv Speakers when you are not around.  You can set the Sound to Standard rather than Amplified (though not recommended for best experience) which is quieter, though obviously the volume could still be set to a fairly  high level .
There is a way to set a Maximum Volume Level but this involves accessing the Service Menu and setting it to Hotel Mode,  the proviso here though it that a setting was changed inadvertently  which was judged to have   directly caused a fault your warranty  (if applicable)  would likely be invalidated. However if you are careful should be fine.
This is the Method but you would need Standard Remote rather than a Smart One
On the remote press: 'Mute, 1, 1, 9, Enter' - This will open the Hotel Options Menu
  • Select Network > Network Setup - NetWork Menu will now Appear
  • Select Network
  • Select Network Settings and proceed with SetUp.   There should be an option for Maximum Volume Level.
Not an option I need myself though.
lesley999
Hi. I followed these instructions but I didn't have network set up option
