Samsung frame connects to 2.4ghz only
(Topic created on: 26-04-2023 08:37 AM)
MCraciun94
I recently got a Google nest WiFi and I notice my frame is connecting to the 2.4ghz network - is there a way to make it connect to the 5ghz instead?
1 REPLY 1
Rob99
Voyager
Have a look at the settings for your router, you should have the option to turn off the 2.4ghz signal. But bear in mind which devices in your house connect to WiFi, as sometimes they don't support 5ghz. The other option would be to name your access points differently, eg 'WiFi2G' and 'WiFi5G'. The you can set your phone to always connect to 'WiFi5G'. Hope this helps.
