Go to solution Solved
Samsung Earbuds+
(Topic created on: 18-12-2020 03:04 PM)
seacider
Will Samsung Galaxy earbuds + work with a 2019 Samsung QE75Q85RATXXU TV. Will the audio delay be a problem? I am told that this TV is only bluetooth version 2 which I find hard to believe.
TessM
Mastermind
I have been unable to any information regarding this particular model Bluetooth, however, you can try to reach our AV Team on 0333 000 0333 or via Live chat.
3 REPLIES 3
TessM
Mastermind
Hi @seacider ,
you can connect Bluetooth headphones to the TV by following these steps: Press the Home button > Select Settings > Select Sound > Select Sound Output > Select Speaker List > Select Active > Select Pair and connect > Select CLOSE > Select OK.
The sound supposes to reach the Buds+ without any delay as long as this is emitted by the TV directly.
seacider
Thank you for your reply. I was concerned that audio delay {latency} would be an issue because the TV is only bluetooth 2 which dates back to 2012. The earbuds are bluetooth 5.  Can you comfirm that this tv ( 2019 Samsung QE75Q85RATXXU ) is in fact bluetooth 2.
TessM
Mastermind
