Replacement for One Connect Box SOC1001N
(Topic created on: 30-07-2024 12:54 PM)
Mario_C
My One Connect box model SOC1001N died, I am urgently looking for a list of compatible boxes (will SOC1001R be suitable? I can buy one but I'm not sure if it will be ok)
5 REPLIES 5
Batsy
Pathfinder
Not entirely sure on the One Connect compatibility. Maybe they can help: https://www.samsung.com/uk/support/service-centre/
Mario_C
Thanks Batsy, unfortunately I checked earlier and there are no answers I am looking for
Ginga_p
Hotshot
Tends to be each one connect box is calibrated to each screen so if you found one on ebay it wouldnt work correctly
G G
Mario_C
Thanks GG, I will continue my search but I think you are right,  so I will try to find the same model of the box
luftpus
Hi Mario, I have the same problem, did you find an answer to this? can you use other boxes or does it have to be exactley the same model? (letters in the end of serial as you describe?)
t
