Replacement fixings for No Gap Wall Mount (WMN-M11EA/XU)
(Topic created on: 05-10-2020 09:26 PM)
stockwep
After moving house I need to install No Gap Wall Mount (WMN-M11EA/XU) for a QE49Q7FAM tv.
I no longer have the original fixing screws and the wall plugs were used in the previous house.
What fixings should be required to secure the bracket to a solid wall?
2 REPLIES 2
Penguinbo
Voyager
Can you get some from that hardware shop? B&q?
The manual for the no mount wall gap will show the screws and plugs and the shop staff my also have advice. sometimes the fittings that come with mounts etc are not the best there can be better alternatives. xx
Shazzkid
Troubleshooter
Anything that will fit and is suitable for the material you are mounting it to.
