Go to solution Solved
Remote control
(Topic created on: 29-10-2020 05:51 PM)
Deneva48
We are considering buying a Samsung 2020 49" Q80T QLED 4K HD. Our last Samsung came with two remote controls, one slim one with very few buttons which we didn't like and a standard button remote, which we much prefer. This new TV only seems to come with one remote,it being the slim type with few buttons. Will the button Samsung remote work with this new TV, it works with our other Samsung and I've tried it on friends new set. It may seem we are being picky, but this slim one isn't easy for us oldies to use, I much prefer pressing a button, and not scrolling through menues or speaking commands to it. Any help appreciated. I did ask local Samsung dealer, but never heard anything back from them
Tehmeng
Pioneer
Yes, all samsung remotes work without any issues
4 REPLIES 4
AndrewL
@Deneva48: Where did you purchase the TV from, as the user manual shows that this model should come with both a standard remote, and Smart Remote. For clarification, please see page 9 of the user manual via the link below.
https://downloadcenter.samsung.com/content/EM/202003/20200325134536922/BN68-10106C-02_UM_QTQ80D_QTQ7...
If you're not sure about how to fully utilise the Smart Remote, I also recommend checking out page 18 of the manual, to give you a better idea of how it works.
Deneva48
Havent purchased it yet, will probably buy from John Lewis, the product spec only mentions one remote. Qled 43” came with two remotes, standard and the slim smart one. We tried the smart one and don’t like it. I am hoping the new tv would work with a button type, or even a universal one.  Difficult to get through to John Lewis for answers. Won’t go into the store as we are not happy to do so during this pandemic.
Tehmeng
Pioneer
Members_Fra
Hi Deneva48,
I bought the QLED 43 QE43Q60DAUXZT model a few days ago but I only found one remote control, the smart remote.
Did you find two?
Ciao e grazie
