Go to solution Solved
Re: Surround sound icon stuck on tv
(Topic created on: 15-05-2017 06:24 PM)
Coggsie
Hi
I Have a UE55KS9000T and have the volume icon despayed on the left.
I have tried to update the TV but it tells me that there is no update.
Kind regards
Ian
ChrisM
SuperStar
Hi @Coggsie.
Let's try a reset of the TV. Go to Home > Settings > Support > Self Diagnosis > Reset.
5 REPLIES 5
ChrisM
SuperStar
Hi @Coggsie.
Deani
It worked, took ages though, like setting up a new tv but why???
teebell816
Although I am responding to the surround sound stuck issue, my problem was the number '3' stuck on the screen. I used the solution noted for this instance and it worked perfectly. My best guess is, any imagery stuck on the screen - a total tv reset is the preferred methodology as a remedy. Thanks so much for your help. It was driving me crazy!
Rotary12
Sorry but resetting the TV is not an option, I will lose all my picture customizations.  That was difficult enough to get right the first time, I'm not going through that again
hellow
the tv thing didn't work for me. unplugging my cable box, which coused a reset, did the trick. no more symble.
