Question regarding Q95T and wired vs wifi internet
(Topic created on: 22-04-2021 06:10 PM)
magneman
Hi!
I have a Q95T which is located in a place with a bit bad connectivity to the wifi, the speed is around half or one third of what the total mbit I have in the internet subscription. However, there is an ethernet cable I can connect it to. To get wired connection speed, do I simply plug it into the LAN input on the one connect box?
1 REPLY 1
Shazzkid
Troubleshooter
There is literally no harm in trying. I don't have any experience with the One connect boxes, but on every device i can think of, its as simple as just plugging in the ethernet cable.
