QN95B cracking backpanel coming loose
(Topic created on: 16-04-2024 12:02 PM)
Knugen1015
I have tried getting in touch with Samsung support regarding this (its under warranty) but no reply from them whatsoever for almost a week now.
My back panel is starting to come loose on the back of my QN95B, see
This is outrageous for a TV this expensive. What a cr*ppy ***** quality.
Every time I watch TV for about an hour or more, I start hearing LOUD cracks from behind the TV, probably expanding from the heat, but it should tolerate it. Not making the whole backpanel fall apart.
What the hell do I do now? When samsung ***** support does not reply??
5 REPLIES 5
AntS
Hi @Knugen1015 ,  Which country are you based in? And which method did you contact Support by?
Knugen1015
Sweden, the contact form on samsungs own website
Gurky
Helping Hand
It should just pop back in, its only tiny plastic clips.
Ginga_p
Hotshot
It just pushes back in. Mine did the same
G G
Members_uXLs64r
Same issue with a Just 2 year old QN95AATXXN.  The frame of the tv gets pushed down at the logo. If i hold the logo and push at the back i can feel the backpanel move a few mm.
About 30 days to late fo warrenty 😞
