26-12-2018 02:07 PM - last edited 26-12-2018 02:59 PM ) in
TVI don't know what to say. I woke up and turned on the TV. As I was in the kitchen I heard the TV turn itself on and then off then on again. I didn't think anything of it but then it started turning on and off continuously. I attempted to go into the menu to try and reset the TV but I could not reach the menu with the TV turning off and on. I read a post where I needed to verify software updates but I cannot do that when nothing works on the TV. Any help would be greatly appreciated.
Solved! Go to Solution.
27-12-2018 02:37 PM in
TVThanks. I returned the TV and got a new Samsung. Did not feel like taking chances.
26-12-2018 06:24 PM in
TVHello
I suggest you start by doing a coldboot by unplugging all devices related to your TV and keep pressing the POWER button for 30 sec After, then you can reconnect them.
Normally it should work properly
27-12-2018 02:50 PM in
TVHello,
Well done, it's better to take no risk
03-01-2019 07:49 PM in
TVMine did the same thing. Q9FN 65" - the first day I had it restarted itself a couple of times which was odd and when I got up next morning it was on. It seemed to forget some settings or change them on it's own and It quickly degenerated after 2 days to a point where it would just continually boot loop via the startup logo and couldn't get it to do anything. I sent it back and bought another one. Fingers crossed, but so far it's great! As a possible diagnostic I did notice that when and if you could get into ambient mode, the picture in the 'water' screen didn't run smoothly but kept slowing or even freezing for a moment. The new one runs ambient silky smooth and hopefully will stay that way.
