QLED 55 Q7 One Connect cable or box fault
(Topic created on: 20-02-2021 07:42 PM)
Mrlargeit
My TV will no longer stay on. It keeps turning off and on and from what I have read its either the One Connect box or the Fibre cable.
One thing though is if I turn on the TV without the one box connected I don't get the picture/Icon to say connect the cable ? Although the TV does switch on and stays on, but obviously no picture or access to menus.
As both the box and menu are expensive just wondering if anyone has able to determine what symptoms correspond to which part is faulty?
Thanks in Advance
0 REPLIES 0
