qe65q70ratxxu and EARC
(Topic created on: 31-10-2022 01:03 PM)
devagx
Hi
does qe65q70ratxxu support EARC? Also where can I buy an ARC and EARC box?
thanks
2 REPLIES 2
Ginga_p
Hotshot
Yes it does by the spec list on the samsung web site. If you get any new ish audio product. (amp. Soundbar) they will have earc capability but check spec first. Hope this helps
G G
JAMES4578
Samsung Members Star ★★
Hi @devagx  This Tv  is listed as having earc support as can be seen here https://www.rtings.com/tv/reviews/samsung/q70-q70r-qled
This was activated with 1387.1 firmware but some had issues, noteably if the Tv if the device was factory reset or jumped straight from 1385 to 1392.
Some members have reported that it is sorted with 1401.0. but not universally.  see more information in this thread https://eu.community.samsung.com/t5/tv/tv-firmware-changelogs-on-german-community/td-p/1846870
There is an earc Adapter from HD Furyhttps://www.keene.co.uk/hdfury-4k-arcana-18gbps.html  A review is here https://www.techhive.com/article/579105/hdfury-4k-arcana-review.html
