Q80T – adding Sources to Home?
(Topic created on: 06-07-2020 10:22 PM)
paulo75
Is there a way to add Source icons to the Home menu? When reading the manual, it says to highlight the Source (ie cable box), and press "up". From there, we should be able to select "Move to Home Screen". But all I see is "Edit".
It would be great to move these icons to the Home screen, since scrolling all the way to the left is a bit of a pain (first world problem I know).
Or, is there a way to access the Source icons faster?
Thanks!
1 REPLY 1
thebearis1
I hope you figured this out but I was trying to do this too and solved it myself.  Go to source on the home bar.  Navigate to the source you want to add and then press the up button.  A menu will apear above where you can edit or "add to home."  You want to select " add to home"  You will then get to to select where the source is placed on the home menu.  Hope this helps.
