Go to solution Solved
Q60A Universal Remote with AppleTV4k
(Topic created on: 25-07-2022 10:20 PM)
Keith-W14
I can’t seem to get the Universal Remote feature to work with AppleTV4k.
When the TV attempts to detect the device none of the controls work. I am then prompted for the model number, which is A2169. That model number doesn’t appear in the list. Scrolling down, I find ‘AppleTV4k’, so I select that. Unfortunately the Samsung remote still fails to work with the AppleTV.
has anyone else had & managed to fix this?  I have a Q75A and the same model AppleTV4k was detected automatically and works perfectly with it
thanks in advance
Keith-W14
As I mentioned, AppleTV works perfectly with the Samsung Q75A upstairs...   It turns out that for some reason the second AppleTV box connected to the Q60A did not have 'Allow control through HDMI-CEC'  enabled. Once I switched that on it fixed the issue.
Actua
3 REPLIES 3
Andy3
Voyager
Do you really think apple will allow a universal controller to work with there apple TV box? This is apple after all they don't allow 3rd party stuff to work with there devices.
Keith-W14
Actua
Andy3
Voyager
How long do you expect apple to allow this for? Knowing apple they will disable this feature soon. Why are you even using a apple TV? There is better on the market.
