PS3 doesn't detect on my Samsung Smart TV. (I'd appreciate if I'd get an answer before Sunday.)
(Topic created on: 16-10-2021 12:30 AM)
I have this problem too
NikolozMchedlishvili
The PS3 was connected with its HDMI and AC power cable to a Samsung Smart TV. And to make the TV identify it, I pressed the HDMI 2 and classified the device type of the PS3 as a cable box.
I did all of this and it appeared in the TV, but later on another day, it didn't, the HDMI 2 stated "no signal". And so I thought I didn't remember something that I did the first day.
I tried changing the device type into all the options and in all HDMI numbers. I got out the HDMI cable from the PS3 and put it back in. None of it worked.
Any ideas what I can do to make my TV detect my PS3? I would appreciate if I could get an answer before Sunday.
8 REPLIES 8
Mors88
Same thing to me to just got the new qa65inch and wont recognise the hdmi or the av cables Samsung please help or I’m buying a Soniq
KoЯnChef
Just bought a New 8series TV.
Couldn't connect PS4 or 3.
For me, I run everything through a receiver.
I ran the troubleshoot function on the video HDMI connection and it fixed it.
I can run everything now.
Good luck!
Priya Jain
Hi,
I am also facing a similar issue. Were you able to find the solution? I also need help with the same.
Thanks
KoЯnChef
My solve remains the same.  Each connection has a trouble shooter.
In my case, the HDMI was not being recognized by the new TV.  After running the trouble shooter for HDMI or was it video? 🤷
It worked.
Find the trouble shooter, run it.  It should work.
It seems the TV has issues recognizing connections.
Mors88
Hey can’t remember where I found it but all I had to do was stay on the what ever Chanel you have your ps on and keep you finger pressed on the power button it will beep a few times to try and adjust to the tv I kept doing it till it finally worked hope this helps
Mors88
Hold power button on ps it will calibrate it hope this help
KCribben
Experiencing a similar problem right now. PS3 worked fine 2 months ago. I moved and now my TV won’t recognize the console. Can’t run the troubleshooter because the TV doesn’t recognize anything is plugged into the port. Tried 4 different HDMI cables. What gives?
what8
i'm having the same issue. i'm about to buy a vizio or something because this is absolutely outrageous. this is supposed to be a quality, established brand and can't carry out basic HDMI functions. HDMI support has been around for over 20 years and a name-brand SMART TV can't even run it. count your days samsung
