Problem with samsung smart tv server not found
(Topic created on: 19-02-2022 06:54 PM)
Riad alafandi
 That is all the information about the tv
And my problem is when browsing for any thing the result is '' server not found''
Please anyone reply to try solve this problem.
5 REPLIES 5
xSteveuk
Mastermind
Hi,
If your Samsung TV says “Unable to connect to Samsung server” you need to reset your Network. To do this, start by tapping on Source on your remote then go to Settings (gear icon bottom left) > Enter > General > Network > Reset Network. This will restore Network settings back to factory defaults
This page may also be helpful to you
Set up your smart TV
https://www.samsung.com/us/support/answer/ANS00062199/
LoisS
I have the same problem with my Smart TV J5500. At the beginnig I had access to websites but only for a few months.
I do not have access to websites and the message is the same 'Server Not Found'.
Obviously it is a problem that Samsung should be solve.
LoisS
I tried it and it did not work.
I tried other options, and it did not work.
And does not allowed to use other browsers either.
chroniclebill
use 2.4g wifi instead of 5g.
That should work ☺️
RL12
check with Samsung your tv and like mine will not connect because Samsung cannot fix old tvs technology and hardware/ firmware cannot be corrected by them
