10-07-2019 09:26 PM - last edited 08-10-2019 04:42 PM
Sadly, the answer is to switch your device to SDR. You can sit in a pitch black room and mess with settings all you want - that won’t fix it.
This means that you have to notice, or know, that the video you want to watch will be streamed in Dolby Vision HDR and change a setting every time (then change it back - what a pain!) to accommodate this.
a) *EDIT* THE INFORMATION IN a) BELOW IS WRONG. I HAVE LEFT IT IN PLACE SO AS NOT TO CONFUSE PEOPLE WHO SUBSEQUENTLY RE-READ IT. IT APPEARS THAT, FOR MORE MODERN TELLYS AT LEAST, THE OPTION ("INPUT SIGNAL PLUS" IN SETTINGS/ GENERAL/ EXTERNAL DEVICE MANAGER) FOR TOGGLING BETWEEN HDR AND SDR ONLY FUNCTIONS IF YOU ARE WATCHING VIA AN EXTERNAL DEVICE SUCH AS AN APPLE-TV OR A FIRESTICK. IF YOU ARE USING THE TELLY'S OWN SMART NETFLIX APP THERE APPEARS TO BE NO OPTION TO TOGGLE BETWEEN HDR AND SDR.
a) If watching via the Netflix smart app on the Samsung HDR telly itself, turn off the HDR settings in the telly’s General/ External Device Manager settings which set the input ports for HDR. Usually called HDMI UHD Colour or Input Signal Plus. (EDIT: NO, THAT WON'T WORK. )
Now the Netflix Dolby Vision HDR video will still play in 4k/UHD but only in SDR. (And only in 8-bit) But, at least, you can see it without having to sit in the coal cellar.
(May cause unwanted changes to other devices connected to the TV)
Remember to turn those settings back on again for non-HDR Netflix videos and for all Amazon etc. videos.
b) If watching via an AppleTV 4k connected to a Samsung HDR TV the following are usually the best Video settings in the AppeTV for everything except Netflix HDR videos. I recommend using them all the time:
- 4K SDR (Yes, SDR!) in 50Hz (UK) or 60Hz
- Chroma 420 (To enable 10-bit on most, not-super-expensive, Samsung tellys)
- Match Content > Range and Frame Rate both turned on.
Now, to watch a Netflix Dolby Vision HDR video in SDR on a Samsung HDR TV, simply turn off Match Dynamic Range (only) in the Match Content setting referred to above. EDIT :SO LONG AS YOU HAVE SET YOUR APPLE-TV TO SDR AS I HAVE RECOMMENDED ABOVE.
Now the Netflix Dolby Vision HDR video which you want to watch will still play in 4k/UHD but only in SDR. (And only in 8-bit)
Remember to turn that Range setting back on again for non-HDR Netflix videos and for all Amazon etc. videos.
EDIT: NOTE THAT, IF YOU ALTERNATIVELY ELECT TO TURN OFF HDR WHEN USING AN APPLE-TV BY USING THE "INPUT SIGNAL PLUS" SETTING IN YOUR SAMSUNG TV SETTINGS, THAT WILL WORK BUT THEN YOUR APPLE TV WILL SENSE THAT IT IS NO LONGER CONNECTED TO AN HDR TV AND WILL PROBABLY ALTER SEVERAL OF IT'S OWN SETTINGS.
EXPLANATIONS:
Firstly, the “best” AppleTV settings shown above will allow SDR Videos and the Home Screen to display correctly and then, when you start to play any HDR video, the AppleTV automatically switches itself to output HDR ( and automatically back to SDR again, when done.) EDIT: UNLESS, OF COURSE, YOU HAVE TURNED OFF THE "MATCH RANGE" OPTION IN ORDER TO WATCH A NETFLIX DOLBY VISION VIDEO.
Netflix outputs it’s HDR videos in Dolby Vision HDR format. Many brands of telly display this OK but Samsung tellys are designed to use the rival HDR10+ format. Dolby Vision formatted videos display badly on Samsung TVs. Full stop!
Amazon Prime output their HDR videos in HDR10+ format so they display nicely on Samsung tellys.
Netflix claim to output HDR in both Dolby Vision format and in vanilla HDR10 (without a +) format. Presumably, if we could get them to send HRD10 (without a +) format videos to our Samsung TVs that would fix the problem. But, I rang Netflix, and it seems (in a very vague conversation) that this is not possible unless our AppleTVs could somehow request it.
Dolby Vision vs HDR10+. Who will win the battle to become the industry standard?
Note that this correct AFAIK on 08/10/2019 and may change in future. Those of us who just bought new Samsung TV sets will be keeping our fingers crossed!
EDIT: MY APOLOGIES FOR THE EDITS!
12-05-2020 11:46 AM
@ikramkhasim wrote:
Not to mention licensing paid by Sony and LG to use the brand I bet! But really if it doesn't work for the rest of us, then it's a PR nightmare.
Most Sonys and LGs suffer with that too.
Dolby Vision might be optimized for pixel-illuminated screens like OLED and plasma and might suffer with backlight based LCD screens. Just an idea. My phone is OLED but supports HDR10+, not Dolby Vision unfortunately so i can't check my theory.
12-05-2020 11:47 AM
12-05-2020 11:57 AM - last edited 12-05-2020 11:58 AM
@LetMeTurnOffHDR wrote:
It looks like the only real solution is to scrap hdr for good and thats it. A stupid piece of technology no one cares about and I bet you show an image to someone and tell them that HDR is off when its actually on they wouldnt even noticd.
Just turn the thing OFFF
I love all my HDR10 stuff but hey my wife can't even easily differentiate between DVD and 4K Blu-Ray so yes we are different
12-05-2020 12:10 PM
@Kettyo wrote:I love all my HDR10 stuff but hey my wife can't even easily differentiate between DVD and 4K Blu-Ray so yes we are different
Agreed. I love HDR when it's done right.
12-05-2020 12:12 PM
12-05-2020 12:27 PM - last edited 12-05-2020 12:28 PM
I for one have never watched a comparison of HDR on the same TV and with the same clntent to be able to say it looks better or not.
Maybe If I had the option to turn HDR off I would be able to actually tell the difference
Play to your TV via a laptop, then you can set any kind of output your heart desires.
I use Potplayer with MadVR, there is nothing you can't set there
Of course you can switch HDR on/off very easily in the laptop so you can check how they compare on the TV. MadVR even has his own HDR mapping but i'm not so much a hifi guru to play around with that, i just let HDR passed through to the TV for processing.
12-05-2020 01:08 PM
Id rather be able to turn kt off on the TV and thats it.
Whats the point of having a smart TV if I have to plug a PC to it.
12-05-2020 01:15 PM
What's the point of buying a HDR TV to disable it altogether?
12-05-2020 01:16 PM
12-05-2020 01:17 PM
@Kettyo wrote:What's the point of buying a HDR TV to disable it altogether?
I second that. I'd rather they get to the root of the problem and fix it.
