Pin code
(Topic created on: 11-12-2021 11:43 AM)
Members_LhxkRIW
I have samsung 55 inch smart and had it for 5 year no issues then today it came up on the screen to enter a pin code to my mobile device now tv wont work as do not know where to input this any suggestions
3 REPLIES 3
xSteveuk
Mastermind
Hi,
This page maybe helpful
What is the default PIN of my television?
https://www.samsung.com/uk/support/tv-audio-video/what-is-the-default-pin-of-my-television/
GalaxyA51user
Voyager
Usually Samsung have 0000 or 1234 default PIN. If these don't work, try 1111.
AndrewL
@Members_LhxkRIW: If the default PIN suggestions don't work for you, then please confirm the model number of the TV, located on the sticker on the back of the device, and I will look into this further for you. I'm sure that the PIN can be reset by a sequence of button presses on your remote, however this differs from model to model.
