Go to solution Solved
AU9000 43 2921
(Topic created on: 11-12-2021 01:23 PM)
KMG
TV
My TV us only a week old and sometimes when I turn it on the screen is pink and there’s no sound. It happens if I use the TV remote or the Sky remote. If I turn it off and back on this sometimes fixes it. 🤷🏼‍♀️
xSteveuk
Maestro
TV
Hi,
Check the HDMI connection from the cable box to the TV That are fully connected
If still have a problem with new tv
Contact support explaining the issue with new tv
https://www.samsung.com/uk/support/contact/
2 REPLIES 2
xSteveuk
Maestro
TV
Hi,
GalaxyA51user
Voyager
TV
Check for connection problems or unplug your TV for some hours. Hope your issue gets solved😊
