One Remote Work With TU7000?
(Topic created on: 20-06-2020 06:22 PM)
JamiePro
Purchased a 43TU7000 TV. I've got a Smart One Remote from my NU8000 TV. It won't connect to the TU7000! Remote is A1811700
4 REPLIES 4
AndrewL
@JamiePro: Sadly the TU7000 doesn't feature Smart Remote support, as it doesn't come packaged with one. If you would like to control external devices using the TV's remote, then please check out the Universal Remote options via Source > Universal Remote. Apologies for any inconvenience this may cause you.
Ric-A
I have just received my 65" TU7000 and it clearly states on the box "ONE REMOTE FUNCTION". Im in the UK
KamilRy
GeovanniCR
Hello, I'm coming late to this, but did you get any answer? I'm looking to replace my One Remote after it got damaged but is impossible to get the right part number
