Q95t 65 software issues
(Topic created on: 20-06-2020 02:34 PM)
keynes
Hi everyone,
Anyone else is having issues with the Q95t? It is very slow when opening apps or switching to other sources. The TV also switches automatically from a wired connection to wireless. Many options on settings are greyed out including updating software. Anyone else experiencing similar issues?
2 REPLIES 2
ExpensiveTV
I'm having the same troubles with this TV
RouDeR
Pathfinder
The 8k lineup tvs are even slower,
If you want to use software update, you should not be in any app, switch to some HDMI input and then you will be able to use the software update.
