Notification Network Cable
(Topic created on: 17-08-2025 01:04 PM)
Jvdkemp
Completely random I get a notification on my Samsung TV that the network cable is not connected.
While it both is connected and actually works (as I get the notifications even when using YouTube or
another app that is connected).
Usually the notification pop up a couple of time and then is away until another random moment.
I managed to a least get to sound notification off, but there is still the pop up in the screen which only
goes away if you 'ok' it.
Just to be clear there hasn't been any change in the connection, the cable, the set up or anything else
and the Samsung software is up to date.
It is the Samsung TV Model code: UE49RU8000SXXN
Anyone got a solution?
Thanks!
2 REPLIES 2
Tourbillon De La Vie
Samsung Members Star ★★
Notification then disappears if button is pressed on the remote? I only see it with fire tv. Never bothered to find out what's causing it as or how to stop it as it only appears after a period of screen inactivity
"Whoever wants to be always right needs to change opinion often."
Jvdkemp
It disappears but usually returns immediately a couple of times, then disappears until a random moment.
And in my case it has nothing to do with inactivity...
