No gap wall bracket
(Topic created on: 13-07-2020 05:51 PM)
Ramsden
Hi. Does anyone no if the no gap wall bracket for the 2019 models of 82 and 85 inch will work with the 2020 models ?
thanks
3 REPLIES 3
caramba80
I have tried and tried and I cannot get my 2020 q95t to work properly with the no gap wall amount. A noticeable gap of 5-7mm is visible. I would be grateful if a moderator from Samsung could clarify which model of the no gap mount actually works with the 2020 q95t. All of them were advertised on the website with no gap fixtures and no gap mounts - but it's just not working.
Ramsden
Hi. But you the mount actually works in the sense the tv stays on the wall ?
caramba80
Yes, it stayed up.
