New QE55Q9F with edge bleed
(Topic created on: 07-02-2019 08:51 PM)
Mike1233
I have bought a week ago a new QE55Q9F television. It is a nice television and the one connect box is very nice.
But when i look at the edge of my screen on the left and right i see a small stripe of a light. Is this normal for a television with this price and quality?
https://www.dropbox.com/s/ww4vfgj42ck564h/20190206_175259.jpg?dl=0
Thanks for any answer.
Edit:
Adding an other picture.
https://www.dropbox.com/s/y28y70ks9aj1eja/20190208_192215.jpg?dl=0
7 REPLIES 7
ChrisM
SuperStar
Hi @Mike1233.
We're unable to view the links you've supplied. Could you resend in a different format?
Mike1233
Thanks for notising.
Is there something wrong with the jpg or with the link?
As jpg, other link.
https://drive.google.com/open?id=1oNJjBEj0H3JiKCiNLxmKpmwpzaT6DXJw
https://drive.google.com/open?id=1h6VvgZVfpfrhq4twTCdJoC57lwLiDtcE
Boyzie1982
I'm getting that it is "normal" or in an "acceptable" range for Samsing QC. It is worse on greys and reds I find. Turning down the backlight on this should help but it is a workaround rather than a fix.
Not sure what can be done about it. If you are in an unacceptable range Samsung can replace it but you may find it's worse on a replacement like I did... it can sometimes be better just to live with it.
Or go with another manufacturer, because Samsung have been really unhelpful with my issues with the TV.
Mike1233
Thanks for answering. I bought this tv new and is 1,5 weeks old now. When i buy a tv i want a good working tv . I have reported this to the shop and they wil call me in a few days, I have also emaild a repairshop for Samsung tv's and they say that it is a problem wiith the tv.
I let now overhere what has happend with this problem.
Boyzie1982
Looks like you got lucky with the response. Ive had two like this. Wont be buying Samsung again! Hope it is better on your replacement.
Mike1233
Today they have brought another tv. The new one works just fine. The image quality is better than the one that is replaced.
So i am a happy man.
ChrisM
SuperStar
Great to hear, @Mike1233! Thanks for letting us know.
