Network interference
(Topic created on: 19-07-2021 04:52 PM)
darthmuppet
Hi all,
I have a UE46D8000, donated by a family member, and I can't open the 'Samsung Apps' app, as it gives me a messages saying 'Network Interference occurred. Please Try again later.'  Netflix works, as do the other suggested apps, and when I try to open the Samsung Apps app, I can see the following using wireshark on my outbound interface:
It isn't my firewall, as I am monitoring outside it, and I have done a factory rest on the TV with no apparent change in behaviour. It looks to me like the app is fundamentally broken somewhere, unless of course my 10-year old TV's app services are no longer available. Anyone have any ideas how to pursue this?
TIA
5 REPLIES 5
Pugs1957
SuperStar
darthmuppet
Pressing the power button doesn’t do anything aside from turn it on and off. It seems to be touch sensitive too.  I’m not at all familiar with Samsung TVs btw,  but I’ve done factory reset and smart hub resets, it says I have connectivity under network status, but the smart hub no longer sees the internet.
darthmuppet
The web browser works too, but what doesn't work is attempting to access any web site using https. Netflix worked yesterday, the Samsung Apps panel didn't work, so i did a smart hub reset and broke everything.
Spent an hour in a chat with Samsung, they concluded it was faulty (I am inclined to disagree), especially know it appears https is an issue.
Ihab020407
Hi, I have UE40D7000, and I can't open the 'Samsung Apps' app, as it gives me a messages saying 'Network Interference occurred. Please Try again later. Also I tried to hold the on/off but nothing happened.
further when opening web browser it doesn't work
can any one help please
Smart TV 2
I am also getting Network Interference occurred message. How to fix this issue? Any suggestions
