Neo QLED TV Antenna Region Change
(Topic created on: 09-12-2021 01:20 PM)
Griff1
My TV has the antenna region set to East Anglia, incorrectly, and it will not receive BBC on Channel 1. I need to amend the region to London. Any idea how I change this setting?
2 REPLIES 2
xSteveuk
Mastermind
Hi,
This page maybe helpful
How to tune your QLED TV
https://www.samsung.com/my/tvs/blog/how-to-tune-your-qled-tv/
Scan for channels from an antenna or cable box on your Samsung TV
https://www.samsung.com/us/support/answer/ANS00062206/
Anonymous User
Not applicable
First make sure your TV aerial is wired directly into your TV from outside first and as mentioned above, retune the channels. If it doesn't work it may be that the bad weather has had a negative effect on your aerial.
