Need a one connect box
(Topic created on: 29-09-2021 08:03 PM)
Poison42
I have a UN55HU9000FXZA however it didnt come with a one connect box. What are my options? And where can i buy the cable and box? Are there more then 1 type of box? Any help would be greatly appreciated!
2 REPLIES 2
AndrewL
@Poison42: Where are you based, and where did you purchase the TV from? I would suggest reaching out to the retailer/point of sale to raise this with them, as the set should have come packaged with a One Connect box. Buying one separately is risky, as the One Connect boxes are typically calibrated to the sets they're intended to be used with, so I'd explore the above option if possible.
Poison42
Thats the issue. It was free and id like to set it up for my kids so i don't have the original accessories.
