KS8000 49" - Light bands on screen edge
(Topic created on: 17-11-2017 08:23 PM)
jammy2049
Hello,
Wondering if anyone can advise on this.
Quite often, there is a noticable thin bar of light most noticably along the left and top edges of the display. It can quite often be distracting, making the image look like it's within a picture frame.
Model Code - UE49KS8000TXXU
Thanks in advance.
1 REPLY 1
SpAwN
Hi,
I have UE40MU6409 and mine has the same issue as yours.
I don't have any other complains- the uniformity of the screen (blacks, whites) is perfect so I think I can live with this.
The screen lottery has been always scary to play as you can end up with even worse than you already have...
