Go to solution Solved
KS 9000 LIGHT BLEAD
(Topic created on: 23-07-2017 09:28 AM)
MONTY38RAY
 JUST BOUGHT 49 KS 9000 GREAT TV ONLY PROBLEM HAS SOME BACK LIGHT PROBLEMS ON LEFT SIDE OF SCREEN IS IT A COMMON PROBLEM WITH EDGE LITE TVS
ChrisM
SuperStar
Hi @MONTY38RAY.
If you're still within the 28 day cooling off period and you're not happy with the TV, we'd suggest speaking to the retailer. Alternatively you can speak to our Support team here for further advice.
5 REPLIES 5
ChrisM
SuperStar
Hi @MONTY38RAY.
We're not aware of any issue with your model of TV. Have you spoken to the retailer regarding this?
MONTY38RAY
Hi no have not spoken to retailer about tv by all accounts from all reviews ive seen
its a problem with edge lit samsung in this model range.
ChrisM
SuperStar
Hi @MONTY38RAY.
Drums1078
I have the same problem  65ks9000. Have any solutions come up?
MONTY38RAY
Hi as my ks49 9000 was still under warranty i have had the panel replaced and now much much better only a very slight bleed from edges thats normal for edge lite tvs..It seems some panels are better than others
