Go to solution Solved
Keyboard in search engine missing K6300 TV
(Topic created on: 18-03-2017 09:29 PM)
IF63
When on the Internet, can not search for anything as my keyboard has disappeared. Unable to reset TV no response from remote control can't enter pin K6300 curve TV
JessL
Voyager
Can you try a soft reset on your TV, @IF63
Go to Settings > Support > Self diagnosis > Reset.
Does your keyboard appear after you've done this?
11 REPLIES 11
JessL
Voyager
shaislet1
Virtual keyboard won't come up to allow to set up of wireless network which also emailed all other functions
I've tried soft and hard reset
shaislet1
No
ChrisM
SuperStar
Hi @shaislet1.
Could you tell us the model code and software version of your TV? Go to Menu > Support > Contact Samsung, or, Home > Settings > Support > About This TV.
shaislet1
I'm returning tv to amazon.  it was likely a refurbish and not bench tested well enough.  I can't update the software either because I can't connect to the internet
Jason85
Hi moderator im having the same problem right now... model code is eu49k5600awxxn i cant search on the internet i cannot reset either as i cant use keyboard to put my pin
UncleGrampah69
Can't find keyboard on my tv to put in Samsung password or wifi Password
natethegoat2
My samsung TV's model code is UN32M4500. The software version is T-KTSAKUC-1280.5. I saw people sayig the self diagnosis works but it is grayed out and says "This function isnt available" when i click it. Please let me know if i have contact samsung or f you can help me. you can email me or reply to me in this thing.
shaislet1
It's been a long time and can't remember. Did you try to do a hard reset on TV? Maybe look up how to do that in the manual or look online. If I recall it's a firmware bug that hasn't been resolved
