20-06-2024 01:59 PM
Hello Samsung Community,
I've been having some trouble with the Wi-Fi connectivity on my Samsung Smart TV (model: QLED Q80T). The connection frequently drops, and sometimes it fails to connect to the network altogether.
Any help or suggestions would be greatly appreciated. Thank you!
Solved! Go to Solution.
20-06-2024 02:36 PM
Do you have the latest firmware which is 2505.4 https://www.samsung.com/uk/support/model/QE55Q80TATXXU/
other Ideas include the following:
switching off Tv for a minute, a soft Reset (pressing and holding power button on Smart Remote for around 5 seconds until Tv restarts ) and rebooting router(unplug from mains) Another possible solution is to change the DNS settings. Go to Network-Network Settings-DNS Settings. Change from Automatic to to 8.8.8.8 or 8.8.4.4. (Google servers) or 208.67.222.222 or 208.67.220.220 (Open DNS)
Some information here https://thevpn.guru/configure-samsung-smart-tv-dns/
20-06-2024 02:36 PM
24-06-2024 06:35 AM
Thank you for you assistance.
24-06-2024 10:06 AM
25-06-2024 06:05 AM - last edited 25-06-2024 06:05 AM
thank you once again
01-02-2025 07:56 PM
I have tried as you have suggested to no avail. is there a suggested gateway setting? This is an older tv, so I might be chasing ghosts.
ex: 255.255.255.0
ip: 198.162.1.14
gateway ??
dsn: 8.8.4.4
