21-06-2022 05:43 PM in
TVI recently bought Samsung Q60A QLED TV. I just want to know if I can use the Dolby Atmos soundbar. if yes could you please suggest any supported Dolby atmos soundbar?
#Q60A #DolbyAtmos
Solved! Go to Solution.
21-06-2022 07:01 PM in
TV@mahendra358: The Q60A does indeed support external devices with Dolby Atmos streams when connected via HDMI (eARC). To enable this feature, please head to Home > Settings > Sound > Expert Settings > Dolby Atmos Compatibility > On.
If you'd like a compatible soundbar, then please check out our range of soundbars via the link below.
https://www.samsung.com/uk/audio-devices/all-audio-devices/?dolby-atmos
21-06-2022 06:46 PM in
TV21-06-2022 07:01 PM in
22-06-2022 02:45 PM in
TVThank you so much Andrew 🙂
22-06-2022 02:47 PM in
TVYes it does eARC.
